Tutorials - CGI (generic) > CGI: Quick guide, Installing Mambo CMS
Tutorials & FAQs: Scripts: Quick guide, Installing Mambo CMS
Mambo is a full-featured content management system that can be used for everything from simple websites to complex corporate applications.
Content management system’s separates the content of a web site (the text, images, and so on) from the framework of linking pages together and controlling how the pages appear. In most cases, this is done to make a site easier to maintain than would be the case if it was built exclusively out of hard-coded html pages.
This Tutorial covers installing Mambo 5.4.2
For more information please visit the Mambo web site;
http://www.mamboserver.com/
Download page;
http://mamboforge.net/frs/?group_id=5
I recommend downloading the latest stable package of Mambo, at the time of writing this tutorial that is version 5.4.2
Prerequisites;
Before installing Mambo you must activate your CGI web space, and SQL database
If you are not familiar with using the Unix command line, please read the following;
http://usertools.plus.net/tutorials/id/18
This tutorial assumes that you have not already installed Mambo in your CGI web space.
Installing Mambo;
Login to the CGI server.
To install mambo in a subdirectory called `mambo`
mkdir mambo
cd mambo
wget http://mamboforge.net/frs/
download.php/6151/
MamboV4.5.2.3-stable.tar.gz
tar xvfz MamboV4.5.2.3-stable.tar.gz
fixphpperms.sh -r
Note; That it will take a few minutes for the `tar` and `fixphpperms.sh` cammands to run.
Configuring Mambo;
Mambo is configure using a webbroswer.
http://ccgi.username.plus.com/mambo/
Now follow the on screen prompts through the pre-installation check and the license.
Step 1, MySQL database configuration:
Enter your MySQL database details as advised by e-mail when you enabled your SQL database.
Step 2, Enter the name of your Mambo site:
Give your site a name.
Step 3, Confirm the site URL, path, admin e-mail and file/directory chmods:
Mambo should have filled in the URL and path fields correctly, just check these and add a contact e-mail address for administer e-mails.
The file and directory permissions should be left as server defaults.
Step 4; Congratulations! Mambo is installed;
Don’t forget to make a note of the administrator password.
Securing Mambo;
One last task is to remove the “installation” directory, to secure you Mambo.
Log back into the CGI server.
cd mambo
rm -rf installation
Mambo is now installed.
You can now login to you very own Mambo site and start adding content.
Chilly
Original Article by: chillypenguin - Edited by: chillypenguin
